alarms for oil injection
rhodesian
Guys,
I have told that my Evinrude SPL 50 HP (oil injection)1997, has an alarm system that will inform me ...if the oil stops injecting, that the motor is about to seize.
Lou Eppell
Re: alarms for oil injection
Not sure if this is what you're looking for, but the following may be of interest to you. Something that I saved from anothers post.
(VRO Horn Warnings)
1 - A steady constant beep = Overheating - The V/6 engines, possibly some others, have a fuel restriction warning which is also a steady constant beep.
2 - A beep every 20 or 40 seconds = oil level has dropped to 1/4 tank. (Late model engine = Every 40 seconds)
3 - A beep every other second = VRO failure, air leak in oil line, oil restriction, (anything that would result in a lack of oil being supplied to the engine).
NOTE - If the warning horn is the black plastic (overpriced) three wire type horn, the warning horn should beep once when the ignition key is turned to the ON position. If it does not, it is either faulty or someone has disconnected it (a stupid move!). At any rate, if it does not beep which indicates that the horn is non functional, find out why and do not run the engine until the problem is corrected.
