Re: Alcohol in gasoline...
Its amazing that for decades the solution to getting water out of you carb or tank was to use ethanol (gas dryer, Heat, etc) and now that its in the fuel its horrible, ethanol is also in many of the so highly touted elixirs that are used to cure the "ethanol problem". Of which none can really do anything to stop the real issue which is phase separation, well there is one product that can help prevent it...that's more ethanol.
Are there potential problems with the new fuels?..yes, are they as bad as what's been so frequently repeated?.no. There is and issue with mixing gas containing MTBE (does the same thing as ethanol) and E10. When these two are combined and then mixed with some water it can form a goo that may plug up a fuel system. Some states have banned MTBE and some haven?t, so its possible to fill up and have the two mixed in your tank.
