Boomyal
- Joined
- Aug 16, 2003
- 12,072
Question on your homegrown delight, the infamous GM 2.2L OHC wonder. <br /><br />My son's car recently started leaking oil prodigiously. With another circumstance to impart some professional mechanical methodology to the young one, I had him thoroughly degrease and clean the engine compartment.<br /><br />Lo and behold, after starting it up, oil is litterally spraying out, front and rear, of the cam tower cover. I think you alluded to this in a prior post.<br /><br />Now we replaced that gasket about 10k mi ago when we did the head gasket job. Incidently this is and 8 bolt cover and the leak is dead middle on both sides.<br /><br />At the time I noticed that the gasket wanted to squeeze out as you tightened the bolts. I did use a sealant but it also squeezed out leaving a big flashing of gasket and sealant. Now the protruding gasket is actually breaking off in that area and that is where it it leaking. I actually bought a second gasket because the first one squeezed out so bad.<br /><br />Any suggestions when I get yet another gasket???<br /><br />Naturally this has to crop up, along with the brake issue, a day before he leaves for college.
