Alge on stainless prop
Sea Rider
Re: Alge on stainless prop
If you are reffering to marine algae, soak prop in a can to soften it, with a 3M green pad apply and detergent brand you like best..
Happy Boating
jestor68
How did get the prop covered and not the lower unit?
Anyway, remove the prop and soak it in water a day or two to soften up the slime. Clean it while still wet. Soap and warm water using one of those kitchen scrubber pads should work.
As suggested, a good pressure washer should work quickly if you don't feel like scrubbing.
Mi duckdown
Could not make Pic bigger BUT. as jestor68 posted. How did get the prop covered and not the lower unit?
a good kitchen/bathroom cleanser such as kaboom or CLR will work wonders as well. however you will need to soak the prop to get the crud to soften.
Grub54891
You take the prop off if ya want.Then clean it inside and out. The best way to stop alge from building up is to spin it at high speed on the open water every day!
Dunnville
The lower unit was replaced end of last season, thanks for the reply's..
Ayuh,.... That's My answer too,.... Run the 'ell out of it,.....
