Align engine
wakina
5.7L V8 Mercruiser, is it best to have the exhaust risers/elbows installed or not installed when performing the initial alignment on a fresh engine? Or no difference.
Thanks
Wakina
Don S
Re: Align engine
It may make a difference because of the weight, but even if you do the alignment with the manifolds off, it will be a lot closer for the final adjustment before installing the drive.
You did see the alignment information up in the Adults Only sticky didn't you?
wakina
Re: Align engine
Thank you for the reply! I will check out the thread that you related to in your reply.
