1995 Searay with a Alpha 1 Gen 2 5.7
Highly confident this is the first time engine has been aligned. Drive came off with just a little tug, replaced bearing and now attempting to align. First pass, almost needed a hammer to get tool in. heavy on top, light marks on bottom. Found the port side lock nut on top to be loose. had to bring front of engine down a lot to be able to get the bar to slide in and out with 2 or 3 fingers. However, grease reads heavy on top. and does not quite register on bottom third. Is this acceptable, or do I need to keep dinking with it to get grease to read even all the way around. Not sure how it can go in and out so easy but be high in the splines. I have read, searched and watch videos. Measured my tool diameter and it is perfect according to another post on this site. only about another 3/8 of an inch and the adjusting nuts will be bottomed out. I have also been rotating engine with consistent results to what I am getting now. Good enough, or time for a pro? Any thoughts appreciated. 4 hours into this and I am tired of it.
just reread one of Don's responses. Said once the bar moves easy, grease tracks mean nothing. Also stated to clamp down locknuts and recheck. Back outside.....
