jslu
Thread starter- Joined
- Jul 31, 2010
- 74
1987 MERC 35 HP SN #177596
I have taken apart and successfully re-assembled several of these lower units without any difficulty, but this time something different happened. As I returned the engine from the full tilt position to the down position, the part shown in the photos fell out from the drive shaft housing onto the garage floor. This part is to help align the shift rod and splined shift shaft during re-assembly.
There are no tell tale marks or part no. on this part
to indicate the correct way to re-insert it into the housing and it does not appear or is mentioned in my Merc manual specific for this engine. Also I could not find any info on line. My question is this:
Which end should be inserted into the drive shaft housing? As shown in photo"A", or as shown in photo "B"?
Thanks,
John
to indicate the correct way to re-insert it into the housing and it does not appear or is mentioned in my Merc manual specific for this engine. Also I could not find any info on line. My question is this:Which end should be inserted into the drive shaft housing? As shown in photo"A", or as shown in photo "B"?
Thanks,
John
