SeaRayboater95
- Joined
- May 30, 2009
- 517
I have a 1979 140 horse mercriser serial #5213648. I replaced the gimbal bearing last spring and removed the drive 2 times after that, once to replace the drive bellows and later to make sure it wasn't leaking. Later I discover an alignment tool and an alignment are required. I have since aquired an alignment tool and it doesn't seem to want to go in far enough. The drive shaft goes in with a little effort, but this tool doesn't want to enter the splines. Any advice would be helpful. The boat is a 19ft. 1979 Bayliner incase that might matter. Thanks.
