Ok I finally got the bellhousing off and went to check alignment and its off, the flange that the u joint bellows slides over on the transom side is worn on the bottom, is there a way to replace this part and if so what is it. I guess I will be replacing the retainer also cause thats showing some signs of wear on the bottom too. Thanks
