Rivergator
- Joined
- May 7, 2013
- 230
I just received my after market alignment tool and went to work to give it a preliminary quickie test (I don't want to make the same mistake I did with my starter and assume it is fine). Right off the bat I am having nothing but trouble. I have a spline shaft that I can insert about 1/4 in to the coupler which is fine because I know the engine is not aligned yet. I tried the same with the alignment tool and it dead stops on the gimbal bearing. I greased it still nothing. Then I got out my digital caliper and measured the 3 stages of the tool and I found them to be out of tolerance or at least I think. The measurements were: first stage 1.000" sb: 1.010", second stage is: 1.1815" sb: 1.150", third stage is: 1.3815 but sb: 1.375. Did I get a defective tool or did I get the wrong tool? My engine is a 1988 4.3 ltr. and the drive is an Alpha One, Gen1. The gimbal bearing is the sealed one (non-greasable), the coupler is part #18643A5 and the spline is part #814819A3. Do you think I have a bad alignment tool or wrong tool for my application
