I have a 1979 6-hp.Evinrude kicker that I ran last year. I discovered that the gasket between the carb bodies (upper module and bowel)was leaking fuel,should have realized much sooner when I could not get a firm bulb on the prime. Ran quite rich for some time. As a result the plugs have fouled out. I'm in the process of rebuilding the carb now.<br />My question to all is this, what might be the best remidy to rid the cylinders/head of this Carbon build-up from the unburned fuel aside from removing the head. I had a friend tell me to fill the cylinders with Kerosene and let it soak for a day,remove plugs and blow out mixture by pulling starter rope! What do you think about this method? Any suggestions regarding this or any other method would be greatly appreciated! <br />
T-290
