rjrobin2002
Thread starter- Joined
- Feb 27, 2010
- 89
I have a 16' aluma-weld boat that I put a brand new 50hp ETEC motor on. The new motor is significantly "my guess is 200 lbs" heavier than the 91 40hp evinrude I replaced and now the transom sits too low and the boat does really bad in shallow water as far as the prop hitting the bottom. I run in alot of shallow water here in Louisiana and I have heck trying to follow my friend in these waters. I am thinking I could get alot of benefit from adding two 12'x12'x20' boxs to my transom on each side of my motor and fill them with foam before welding the top on them. My thinking is that this would lift my transom several inches which would also lift my motor out of the sand several inches. Probably help my plaining out also. What do you guys think?
