almost died
bobjoe1
I have a 40 HP evinirude and an auxillary 9 hp. Out on the lake and headed back in rough conditions and big motor failed. It died and would restart but acted like it was starving for gas and would sputter and die. No one around and i started the small motor just to get off the lake. Same thing would start but then sputter and die. Finally got it going but had to choke it all the way to dock as waves were coming in the boat. Very scary. With both motors acting up could it be bad gas . I just filled the 25 gallons tank 2 weeks ago and have had it out 3 times and everything was fine until today. If the fuel pump then what are the chances of both motors acting up. Any suggestions would be appreciated
coolguy147
Re: almost died
are they running off of the same fuel tank? try to hook up a portable and then see how they run.
dazk14
Ensign
Re: almost died
Extremely rough conditions... possibly built in tank vent took on water
kbait
Re: almost died
Pull the connector and pump some fuel into a jar. You'll see water/milky sludge on the bottom if contaminated. If so, get 'em running and warmed-up quick w/fresh fuel. They don't like water!
bobjoe1
Re: almost died
do I disconnect gas lines at carbs and pump new gas thru
kodibass
Re: almost died
Scary stuff, been there done that, I always run my backup kicker on its own tank' I keep it fresh no more than 2 months old then I change it, I add stabil & a cap full of marvel mystery oil, let us know when you find the cause,
1946Zephyr
Re: almost died
Yep, I'm betting on the same thing. Contaminated fuel.
