Drivewayboater2
- Joined
- Aug 21, 2019
- 384
Trying to pull the bearing carrier out. Heat and homemade puller has broken some of the rear end of carrier. Considering breaking away the rest of the rear end of carrier and taping prop shaft from side to side.
Saw some other suggestions using the prop with metal plates to pull carrier and prop shaft together. Will the shaft carrier and rear gear come out as one unit? Does the shift shaft need to be removed before pulling out? Any help would be appreciated.
