newtoboat101
- Joined
- Jul 9, 2015
- 407
bringing boat boat out of winter storage was having water flow issue ,changed engine water pump, thermostat and decided i would check impelleron my alpha 1 gen 1 outdrive,so i dropped the lower outdrive off of the upper ,upper stil attached to boat ,put new impeller and gasket(the kit) on go to re attach lower to upper and can not get on ,so i take upper off boat ,upper is in forward(shifter) position when i take it off,so on a bench ,i put it together, goes together fine i,but i can not lock into either forward or reverse ,prop and u joint shaft can still be forcably moved ,never truly locks in place ,so took back apart ,and turned lower shift shaft CW and prop CCW and everything moves, the impeller shaft moves ,the prop spins,same with reverse ,it will move to neutral and everything is free ,i am assuming its something with lower unit any ideas or suggestions thank you
