Alpha 1 Gen 1 Water Pump Problem!
Landon
I have twin 1980 485 mercruisers with alpha 1 gen 1 outdrives I'm not sure what the replacement pump is I have ordered a Sierra 18-3320 Pump Housing kit and it did not fit, the lower housing did not fit into the bearing. Any help would be appreciated. I believe it is the Sierra 18-3317 but I want to be positive before I order another pump. :confused::confused::confused::facepalm::facepalm::facepalm:
achris
More fish than mountain goat
Re: Alpha 1 Gen 1 Water Pump Problem!
1980 is MC-1, not Alpha One. Got serial numbers from the drives? One more question. Does the lower drive-shaft have a pre-load pin in the top of it?
Bt Doctur
Do you have the pre-load pin on the driveshaft?
Landon
1980 Mercruiser MC-1 Water Pump Replacement?
I have twin 485 mercruisers with 1980 Mercruiser MC-1 Outdrives
I am not sure what the replacement pump is I need the part number (I want a complete water pump housing kit w/impeller)
I ordered the sierra 18-3320 but the lower half of the housing did not fit into the bearing. I want the correct pump before I have to pay again!
I am unsure if It has a pre loaded pin (how do I check if it does?)
The outdrive serial number is 5719792
Also another quick question 1980 485 mercruisers (3.7L) what oil filter fits this engine.
Landon
Need Part Number for 1980 Mercruiser MC-1 Water pump housing kit
Thought It was the sierra 18-3320 but the lower half didn't fit in the bearing
I believe it is the sierra 18-3317 but im not sure
ktbarrentine
Re: Need Part Number for 1980 Mercruiser MC-1 Water pump housing kit
Hmmm....You seem to have three current threads going on this problem. You only need one thread. People have been replying to your first thread here:
http://forums.iboats.com/mercruiser...-1-water-pump-problem-606928.html#post4228994
A moderator can help single up your lines here. Please go to the first thread and answer the questions posed so we can give you the right help needed.
KB
Don S
You need the 3317.
All threads about the water pump kit are now merged together.
Please only post 1 time on a particular subject, then reply to that thread for additional information on the subject if needed.
Re: 1980 Mercruiser MC-1 Water Pump Replacement?
The Original oil filter PN from Merc is 35-802885Q here is every thing that number crosses to now save your self some change.
Fram: PH8873, PH 30, PH 13, PH5 (the ph5 and ph13 have anti drain back valves in the filter good feature for the 470)
Sierra- 18-7824 BOSCH- 3322
Mallory- 9-57811 CHAMP- PH454
AC Delco- PF454, PF454CL, PF454FCL CARQUEST- 84099
AMS OIL- EA059 CRUSADER- 201104
BALDWIN- B1438 DONALDSON- P550507
AUTOEDGE- AL8873 FIRESTONE- TF454
FLEETGUARD- LF16109
HOPE THIS HELPS
(Right now, I am running the Fram PH-5)
Landon
I have a preload pin its the same as the outdrive on the right
Landon
Thank you so much for the answer!
