Alpha 1 Gen 2 double clunk forward gear.
2009 Mercruiser 5.0 L TKS Alpha 1 Gen 2 drive 140 Hrs about 1/2 the time I go for first trip of the day when engaging forward gear at 1,000 rpm or less I often get a slight double clunk before full forward is fully engaged . I presume the remote shift cable needs adjustment . It only seems that this happens on the first shift of the day into forward , no issues in reverse .Roughly speaking how much of an adjustment to the remote shift cable barrel do you think I should need to give it a full initial engagement into gear .I followed Shift Cable Installation Alpha Models Drive Unit Installed from internet , my unit has a simple 2 cable system , the remote shift with shift assist and the cable going to the sterndrive .The instructions for standard RH drive read : Remove remote shift cable and shift assist assembly , ensure shift lever adjustable stud is at bottom of slot.Shift remote control into Forward gear past detent into WOT position , Place drive unit into gear by pushing in on drive unit shift cable while simultaneously rotating prop counterclockwise until shaft stops. This will ensure full clutch engagement , maintain a light pressure on the drive unit shift cable to hold it at the end of travel this removes all slack.Then lightly pull on remote shift cable end guide to remove slack from remote control and cable ( I had about 1/8" of slack ) now adjust plastic barrel on the remote cable to align attaching points with shift lever clevis pin hole and the stud .When I adjusted the barrel so that connection points lined up while the drive unit cable was in fully I had to move the barrel toward the helm probably a good 3/16" of an inch . It tests fine when in neutral prop spins freely and fully engages in reverse and forward in the driveway but havent done water test yet . Any comments ?
Your idle RPMs are too high. If you continue to attempt to shift gears bear 1000 RPN, you will take out the dog clutches
Thanks for your reply , maybe that is my main problem I thought Idle after warm up was about 800 but book reads 650 . This being a carb engine it usually takes about 6-7 minutes to warm up at dock , I will reset my idle down a bit and reset the shift cable barrel back close to where it was instead of messing with that .
That is 650 rpm in the water, not on muffs
Scott when you say set RPM in water not on muffs do you mean it should be in gear as my manual says 650 in neutral but no mention about being in water or on muffs.?
