alpha 1 gen 2 gear oil ?
streetwise83
i am new to the boating world but have been a mechanic for a while i just wanted to make sure it would be safe to use synthetic royal purple 75w-90 gear oil in the lower outdrive unit? also the engine is a 4.3 mercruiser would it be alright to use a standard pf47 ac delco oil filter. all help is greatly appreciated.
Re: alpha 1 gen 2 gear oil ?
Welcome Aboard to the forums here at iboats,..........
Oil Opinions run alittle High here sometimes,.........
Rather than tell you what You should run in your Boat,........
I'll tell ya what I run in Mine,.......
That would be Mobil 1, 15W-50 in My old 4.3LX,........With NAPA Gold oil filters.....
And,......
Either Mobil 1, or Penzoil Syn(whichever is on the shelf when I get there), 75W-90 in My Alpha 1 outdrive.........
The Trim,+ P/S get either ATF, or Hyd.Oil,.... Whichever is Handier..........;)
streetwise83
thank you that helps me make my decision. i am also running mobil 1 15w-50 and it is a good reassurance to know that someone else is running similar products without any problems. once again thank you
