..... I read somewhere that vacuum testing on these drives is not recommended. Best not to check vacuum?
Bollocks! When you UNDERSTAND how things work you can make the right 'judgement' call. Forget what 'other people' think (becuase most of the time they don't!), and apply logic to the problem. In this case ask why there are 2 seals ('back to back') on the rotating shafts that have water on one side and oil on the other. Then apply your knowledge of lip seals.
So, let's science the s..t out of this.... Lip seals best seal in one direction, and the higher the pressure the better they seal (without applying ridiculous pressures!). So, one seal faces the oil, and is oriented so that the oil can't get out, but if it was the only seal, the water could be sucked in past it. Like when you run the drive, the oil and gears heat up and you shut it all down. As the oil cools the pressure becomes slightly negative with respect to the surrounding water, and Bob's your aunt and in goes a little slurp of water. Do that enough times and you get a belly full of water and it's goodnight gears. A drive pressure test is very good for picking a leaking OIL seal. But what about the other seals? The ones facing the water. With those in place you eliminate that little slurp of water... So how do we test them? We put a negative pressure (a vacuum) on the inside of the drive. The oil seals open up enough to try and pull air into the drive (to reduce that vacuum) and the water seals now 'lock up', or should. If you see a lose of vacuum, means a water seal is leaking. The only 'qualifiers' on a vacuum test are the shift shaft seal, (only one as it's not a dynamic shaft) and the input yoke, and although it's dynamic but being inside the bellows, it does not have water on the other side (or at least shouldn't
) So you start pulling a vacuum and if the shift shaft seal is a few years old, it may start to leak at around 6" of Hg. That's normal. The drive should never see that sort of 'negative pressure' anyway.
Jcris said:
I should have this back together this afternoon and if all goes well a driveway test on muffs. What kind of temps would be considered normal in that area?
If you have good water flow to the drive, then the engine shouldn't get any higher than thermostat opening temperature.
Chris.......
