Alpha 1 Gen 2 trim tab position
oldjeep
Changed the prop and had to install an offset trim tab. Don't remember which side the tab was turned to.
help
Don S
Re: Alpha 1 Gen 2 trim tab position
Center the tab, run it and adjust as necessary.
oldjeep
I know, but there is a side it needs to be biased towards just based on prop rotation - figured that someone would know.
Oshkosh1
Ensign
Based on Newtons third law of motion, if you have a clockwise spinning prop, the "P-Factor" is to the left. However there are many variables/imperfections in individual hull and sterndrive setup and/or transducers, pitots etc... that may mitigate or exacerbate this.
So what does this say in a nutshell???
Exactly what Don stated...Put it straight, run it, adjust one "notch" at a time in the direction of your yaw, until the tendency of uncommanded turns one way or the other is gone.
And the smaller offset trim tab may not perform(based on reduced rudder area)as the larger one.
If just countering for torque and nothing else...then you would put it tail to port if looking at it from the stern.
oldjeep
Thanks. I did use a full sized offset tab, I used a "performance" tab in the past with a different prop and it was fairly useless.
Don S
Do you have power steering?
achris
More fish than mountain goat
And thus completes 'Rocket Science 101'....
achris
Power steering is always an option on Mercruiser engines (and sometimes standard fitment)... Maybe the boat dealer didn't want to offer it as an option...
Start with the trailing edge slightly to port, then adjust from there....
Don S
Bayliner may have used no-feedback steering in the newer models which would negate any trim tab feedback.
