I hear a knocking toward the back of the boat by the outdrive, I think its the u-joint. Where can you get one cheap? Or if the yolks are ok, I may just go with the cross & bearing. I read you may be able to even use just a automotive u-joint assembly for this or napa carries the c & b? What does everyone else do for this?
Outdrive Serial: 0M419299
Outdrive Ratio: 1.81R
