alpha 1 gen 2 upper unit
scr350
serial #od574021 i took the old drive shaft seal out of the case and my new kit came with 2 of the same seals, seloc manual shows 2 seals do both these seals go in? it had the spring facing downward, is this correct ? i also have a bigger seal that looks like it might go on the driven gear shaft but again mine doesn't have one there at all i want to make sure these seals are in correct before i reassemble it any help will be greatly appreciated !:confused:
scr350
Re: alpha 1 gen 2 upper unit
thank you ! i still have a seal that's a little bit bigger then the 2 bottom seals and the exploded view doesn't show where it goes. i wonder if this kit is like a generic kit and that seal isn't used.
achris
More fish than mountain goat
What's the part number of the kit? Maybe I can have a look at it and see...
Bt Doctur
post a pic of the drive. Alpha uses 2 different size seals, Alpha GEN II uses 2 of the same size seals.
achris
Serial number of the drive is in the top of the first post... and it is a gen II....
I suspect it's a non-genuine kit, and sierra/glm/mallory/some chinese mob have made a generic kit for both drive... :facepalm:
Chris......
Bt Doctur
Sierra kits are specific and work well.
FYI, the original double lip carrier seal merc used for years behind the U jooints 483320VGO is still available under National .seal is now 712250
scr350
seal kit.JPG this is the seal kit i got off ebay from dgmarine,
achris
That looks like a generic for the 2 different drive shaft housings. The seal that's slightly larger than the 2 smaller ones is only used on the MC-1, R, Mr and Alpha One housings.
Discard it for your housing.
Chris...
scr350
cool, thanks so much. i was scratching my head over that seal, but the 2 seals that are the same do go in together ? wonder why mine only had 1 seal in it. well hopefully i will get it put back together tonight and pressure tested, THANKS AGAIN
