Alpha 1 Gen II Gasket
teamrevo
I am getting ready to replace the water pump and want to make sure I have all the needed parts before starting. I have the water pump kit and the drive oil, but was wondering if there is a gasket inbetween the upper and lower outdrive that needs replaced on the reassembly?
180shabah
Re: Alpha 1 Gen II Gasket
There is an o-ring for the oil passage, but no gasket.
Head up to the adults only section - get your self the manual for your drive.
cr2k
There is a quad ring between the upper and lower. Usually comes in the impeller kit along with drain plug gaskets.
