Can someone please explain when I should and should not have continuity on this switch...the switch is new and the engine shifts smoothly into and out of gear but I thought this was supposed to interrupt the ignition momentarily when I come out of forward gear ( I`m assuming that means momentary continuity coming out of gear and no continuity otherwise). My switch has no continuity until I am about 25% throttle in forward and then it has full continuity from 24 - 100% in fwd. I`m testing continuity by disconnecting both sides of the switch, connecting a 2 amp source on the white wire and checking with a test light on the black wire for when the switch is continuous.
The boat seems to run fine, more of a curiosity than anything.
Thanks in advance for any replies
Zeke
Zeke
