I just replaced the impeller in my alpha1 gen1. I pulled the plastic housing (where the copper tube connects to, I think it is called the water pocket cover) off the upper unit to inspect it. I need the torque specs for these four bolts (found something that said 30-50 inch\lbs, that is a large range). I would also like the specs for the rest of the bolts that connect the lower unit to the upper. I came across something that said 38 ft/lbs for the hex bolts. but I do not know if this is correct. It is on a 3.0 mercruiser. I ordered a manual but it is not here yet. Thanks
