alpha 1 gen1 torque specs
Status
Not open for further replies.
Pikey23
I just replaced the impeller in my alpha1 gen1. I pulled the plastic housing (where the copper tube connects to, I think it is called the water pocket cover) off the upper unit to inspect it. I need the torque specs for these four bolts (found something that said 30-50 inch\lbs, that is a large range). I would also like the specs for the rest of the bolts that connect the lower unit to the upper. I came across something that said 38 ft/lbs for the hex bolts. but I do not know if this is correct. It is on a 3.0 mercruiser. I ordered a manual but it is not here yet. Thanks
Re: alpha 1 gen1 torque specs
Ayuh,... The OEM Manuals are Free in the Adults Only section at the top of this forum...
Pikey23
wow, that is awesome. Thanks
dubs283
water pocket bolts torque = tight, put perfect seal on the threads before installing them
upper/lower connecting nut torque = tight
ziggy
Where do I find These manuals
you can't any more. they were deleted. likely to copy right.
tight? how tight is that?
per s/m #6
water pocket cover bolts, 30-40 in lbs
gear housing to drive shaft housing, 35 ft. lbs
dubs283
uh, tight? - german torque (guttentight)
tight is tight, never once put a torque wrench on any of those bolts/nuts - haven't had one come apart yet
besides i don't have an open-ended 5/8" torque wrench for the two nuts on either side of the drive - and using a crows foot isn't gonna give the right torque anyway
i use my torque wrenches where they are most definitely needed:
-pinion nut
-lower driveshaft bearing retainer (when applicable)
-checking/setting rolling torque
-bearing carrier/upper retainers - yes i use the chart in the manual for applying 200 lb/ft torque
-top cap bolts
and i know all the torque specs by heart cuz i love drives
paultjohnson
My Clymer Manual reads for 86 thru 89 Alpha 1s Water pump Nuts 60-90 In lbs Screw 30-40 in Lbs Anti cavitation plate nuts 28 ft lbs gear housing fastners; Nuts 35 ft lbs Allen head screw 28 ft lbs if you trust Clymer FYI :D
Status
