Alpha 1 gimble bearing replacement
blownmirage
I know that there are links to gimble replacement, but does anyone know if the gimble bearing will come out with just the outdrive pulled off, I just bought a boat and the bellows were replaced last year, but not the gimble bearing, I am replacing the engine due to cracked block, I already have the engine out and the outdrive off, just thought I would change bearing now while I have it apart I have an extra bearing I bought for my last boat and never used, but maybe not if have to pull all apart including all the bellows.
Dan F.
Re: Alpha 1 gimble bearing replacement
If the engines out and the drives off just use a drift and hammer from inside the boat and drive it out. During normal maintenance a slider hammer with 2 or 3 jaws from outside is the normal method. Only need to remove the drive.
Don S
What year is your Alpha I ??????
blownmirage
I can't find the bearing I bought so I will get new one and see if it fits through
gimble ring.
