boatsnbeats
Thread starter- Joined
- Sep 12, 2009
- 8
I heard a clunk the other day while towing a tube with my 1988 twin Merc 5.7 Cruisers Inc. It wil no longer stay in gear with the engine running. I had the boat pulled out and tried to manually shift with the engine at idle but the prop would only nudge barely when shifting. I can get it to lock with the engine off and turning it manually in forward and reverse but in forward gear I can force it passed one "stop" before it locks. I then drained the lube and found a fair amount of paste and flakes on the drain plug. I had some of this when I drained it in the spring but I have only been out about 4 times this year. I am now guessing it is a worn or broken clutch dog and have heard that the expense to rebuild is more than the cost of a new lower unit from sterndrive engineering. How can I know for sure that it is the lower unit and is it ok to just replace the lower and not the upper unit? I looked in the top cover before I drained the lube and the upper drive gears look like new. There is only 275 hours on the motors. Any other ideas? Thanks everyone. This forum has saved me a lot.
Eric
Eric
