Alpha 1 ratio
dmweyrauch
How can I tell what gear ratio my alpha 1 is its a 5.7 engine but im thinking someone switched the out drive, Is there a way of telling wht it is.
Don S
Re: Alpha 1 ratio
Look on the port side of the upper gear housing. Should be stamped in the same area as the serial number.
joncrisler
Re: Alpha 1 ratio
It is usually stamped into the metal of the drive, if I recall correctly. you will see a number like 1.5 or 1.84 or 1.32 or 2.0.
AZSenza
Re: Alpha 1 ratio
My problem was just the opposite, my last boat came with a 4 cylinder and the 1:87 ratio (I think) and got a 5.7 swapped in. MAN it had a holeshot! Is that the engine that came in the boat? Also, the higher ratio drives could be ordered for "High Altitudes" to improve performance.
