Knot Waiting
- Joined
- Jun 23, 2006
- 761
How fast should water flow through the engine block. I mean if the impeller in the outdrive is turning constantly and so is the water pump shouldnt it just run in and run out? Or does the thermostat open and close like a closed loop cooling system?
The reason I ask is because when I had it hooked to muffs I didnt have any water leave the exhaust for the little bit I ran it (shut it down because I got nervous).
88' Alpha 1 'r' 350 Merc
