alpha 1 shift cable kit question
paultjohnson
does anyone know where the small black insert that comes with the merc shift cable kit goes 86 alpha 1 thanks
Fishermark
Re: alpha 1 shift cable kit question
It is a grommet that goes in the inside of the transom assembly - from inside the boat - where the cable goes through.
paultjohnson
thank you i would think thats gonna be tough to access but I will take a look much appreciate !!
Fishermark
If your old one is still there I wouldn't bother replacing it unless it is worn out (not likely).
paultjohnson
thanks again fishermark I will take a look w a mirror and hopefully the old one is good 2 go
