Re: Alpha 1 trim issue
I can only trim down. Trim up and trailer do not work. Ideas?
Sure, since neither trim up nor trailer work, I would suspect the "up" solenoid. Take a look back near the stern, should see two solenoids next to each other. the one with the blue/white wires is the up solenoid. On the front of the solenoid there is a small b/w wire and a black wire. With a voltmeter + probe on blue/white wire have someone hit trailer switch. If you measure 12V the switch is OK. If not look for a broken b/w wire either from the trim limit connector or control handle. Next jumper from the large b/w wire to the red +12V terminal, pump should run. If it does and you have 12V at the solenoid terminal you have a bad solenoid. If you don't have a voltmeter, jumper from the red terminal to the small b/w terminal, pump should run if solenoid is OK. Good luck.
