Since the unit is apart, tried to remove the bearings to check them out. Bearings seem stuck on the drive gear. Unit had water when the bellow broke but oil was changed out within the day.<br /><br />Have taken off the nut at the end of the yoke, seal carrier is off, yoke is also off. The bearings won't come off, going to put it under a press-should I?<br /><br />Are the bearings supposed to slide on to the gear or are they pressed fit? The book desciption seem to indicate a minor press fit that the nut wll be able to work.
