JoLin
Thread starter- Joined
- Aug 18, 2007
- 5,146
The screw holding the wire to the bellhousing on my port drive is frozen. Can't loosen it (tried heat gun and PBlaster) and I'm starting to bugger up the screw head. On the starboard drive, the wire is broken. Haven't tried to remove the screw(s) there yet, but don't expect much better luck. I assume I'll need to drill the heads off the screws to get them off, or cut the wires.
I know I need to buy 2 continuity kits, but it's doubtful that I can use the same mounting screws and holes. Anyone drilled and tapped new mounting holes for this? Tough job? I've never actually used a tap, so looking for a little guidance/moral support.
