alpha gen2 question
c03camson
Goodmorning!! Got a quick little question... I changed my impeller a while back and noticed that after I run the boat if I leave the raw water in the engine it will leak out from the lower unit. Is that normal? I never noticed it before but then again i was never looking.
I didn't pressure test anything when I did the impeller but it definitely sucks up water a lot better than before. Thank you. 2003 5.0mpi alpha gen2
Re: alpha gen2 question
Ayuh,... Some water drains out, but the motor is FAR from drained...
c03camson
Ok I just had never noticed the water leaking out if I didn't drain it. I want to make sure its not leaking from inside the lower unit and getting into the Ujoint bellows or something.
