Alpha I Gen II Outdrive Oil Monitor System Oil Leak
Harritwo
The small hose from the transom to the drive has cracked and developed a leak. Is it possible to replace the hose without puling the drive? This is the 10" hose attached to the transom thru hull fiitting and Mercruiser shows it to be 10" in length.
Pete104
No!
And if it's leaking, you have other potential problems waiting to happen. Like shift cable & bellows, water inlet hose and don't forget the u-joint bellows. And you may as well change the trim senders while your at it!
Harritwo
Just to give an update, what brought up the question was i had a drop of oil showing on the outdrive on the forward end. First glance said the oil monitor hose was leaking. However, Got an inspection camera and started looking, the line was dry but i could see oil around the shaft.
Did a pressure test and discovered that the seal was leaking so carried it down to the local merc dealer. The main shaft seal was pushed out of the carrier, was told this was a known issue with the merc's Replaced the carrier, the seal, the impeller and filled it up with new lube. Fast service and back on the water. Dealer stated that the "mod" is a new carrier with a hole which is clocked to the forward side so any water will drain out instead of sit and freeze.
George
