mschmidt33
Thread starter- Joined
- Sep 7, 2010
- 110
2009 Tahoe Q5i 4.3 TKS/Alpha I. This is my first year winterizing and I asked my dad and he said just put 4 gallons of coolant in a bucket, suck it up the outdrive, pull t-stat housing and dump in another gallon?
So, I poured 4 gal into a bucket, hooked the muffs up and started her up. At about 1300rpm, I noticed I was not sucking up the coolant quickly at all, more of a slow suction into the engine. After a minute and my gauge getting close to 200F, I put an end to it flushed with water (too cool down), pulled the 5 petcocks > turned over to blow out > replaced, and then poured 3 gallons down the 6 hoses and t-stat. Thus, I think I'm protected.
Question: Should I be worried about the impeller? I was under the assumption that it would suck the coolant up? We do have a lot of sand in our lake and I run it shallow at times. Thoughts? Only 200hrs on boat.
Mike
Mike
