Re: Alpha I leaking outdrive fluid. Please help
I had the exact same thing happen to me this spring. It was the first time I winterized an I/O. My biggest fear was a cracked block. The engine was fine but I had a puddle of lower unit fluid on the ground when I picked the boat up. I took it to the local boat mechanic and they pressure tested it. They found a bad shift shaft seal. <br /><br />Of coarse it's one of those deals, since it's apart probably should get all the little things fixed at the same time. So they replaced the impeller, gimbal bearing, worn out trim sender, speedometer sender, etc. The cool thing is at the moment all my gauges work. So the final bill was $500.00.<br /><br />Hope that helps,<br /><br />Jeff
