Alpha losing gear oil
CurrentObsession
2001 Stingray MS200
4.3L, Alpha 1
Been out with boat several times now since getting a new engine and have had to add gear oil to the reserve tank at the front of the engine after each run. I figured that some air needed to be worked out of the line and it is somewhat normal for an engine swap, but I have added probably the volume of a full reserve reservoir, so now I am wondering if I have a bigger problem?
​Reservoir is not milky, no oil appears to be in bilge or on the water at back of boat while on the lake, where is it going?
​Mechanic changed the impeller while doing the engine swap, could that have something to do with it?
Bt Doctur
If your adding that much oil you have a leak or the drive was not filled properly .the first time.
