Fiat4Fun
- Joined
- Sep 14, 2009
- 229
SO, finally got my trim sensors replaced, now it's time to reassemble the rest of the drive.
I have watched a few videos, looked over the factory manual, and I think I am ready! I got all Mercruiser original parts, adhesive, and tools on hand, but want to make sure I have the sequence down. Any advice would be appreciated.
Here is a water down version of sequence of the procedure.
1- Attach water line to gimbal housing, Attach u-joint bellows to gimbal housing with clamp pointing down opposite of shift cable bellow
2- Attach Exhaust bellows to bellhousing
3- Attach lower shift cable housing to bellhousing, slide shift cable bellows on outer housing
4- Feed outer shift cable into boat, secure. Attach shift cable bellows after mating bellhousing, connect water hose, attach side pins
5- Attach u-joint bellows to bellhousing using bellows tool, tighten clamp
6- Attach exhaust bellow to gimbal housing using bellows tool, tighten clamp aligned with acmes hole.
7- Assemble lower shift cable with inner housing and adjust length, grease cable to drive connector.
8- Reconnect trim sensors
9- Replace drive with new gasket and water o ring, Grease drive shaft where it goes into bearing and motor, fill with oil
One quick question that I have with the kit that I got, it came with two hoses for the water line. One is molded and the other is just a straight piece. The one that came off looked like a straight piece, but the new molded hose looks like it would fit well coming out of the gimbal housing. Which is the right one to use?
The kit came with additional o rings and parts, I assume they include everything for different drives.
What did I forget????
Any advice is appreciated.
Thanks
Bob
Thanks
Bob
