Blueghost924
Thread starter- Joined
- Sep 19, 2013
- 250
I need to replace the water impeller from my Alpha 1 Gen 1, and the sterndrive is still installed. I've heard of people removing the entire sterndrive to get to the lower unit for the impeller replacement, and I've seen where folks raise the sterndrive and simply remove the lower unit (while leaving the upper still installed). All 3 bellows are brand new and the gimbal bearing is new (I've had them recently by a local marine mechanic).
Is it recommended I remove the entire sterndrive or just drop the lower unit from the upper while leaving it still installed to replace the water impeller? If I just remove the lower unit only, is it still necessary to put it all the way in forward? Thanks.
