Alpha One Gen 1 Shifter Operation and Cable Movement
theorifice
On a Carver Santego 30 (1988) with dual controls connected to a pair of Alpha One Gen 1 drives (5.7) Three seasons ago, I changed the lower shift cables (they were closed to being seized up!) and after adjustment, all of the lower shift cable operations and measurements were in spec.
In the last season, I've had a bit of trouble getting into reverse where I need to give it an extra bump past idle to get into gear. As far as I know, the Idle Reverse position should have been the maximum travel of the upper shift cable to get into gear so this was surprising. I assumed that the upper shift cable was worn so replaced that last week. During replacement I inspected the operation of the control and noted that the shift cable travels more past the idle position both in the forward and reverse directions. Is this expected? If not, are there adjustments to be made? Any other recommendations?
Here's a video describing the behavior:
And picture of the remote:
ROY WILLIAMS
cables of the maintenance oil of the shift / cables .
rubber hose of the oil cables .
Roy Williams MCM470 ENGINE SHIFT CABLES OIL !
theorifice
I measured the output on the other end of the control and at the idle positions, it's just at 2 7/8 (or a little under) which I think is the lowest end of the specification (3" +/- 1/8" according to achris). For this control, is there any adjustment that could increase the travel of the shift cables slightly?
dubs283
Yes
You can relocate the cable end for the controller in a different hole location. Based on the video there are a few options
Try for one that allows for 3" of travel. You may then need to make further adjustments at the shift plate assy on the engine
theorifice
Yes
Wouldn't the hole furthest from the arm be the longest travel? I'd love to find a manual for this controller but haven't had any luck.
The shifter cables are the cables are the outer ones. Which hole give larger travel?
