FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Re: Alpha one gen 2, installed UJ bellow on transom first
Manual says to put it on the bellhousing first, then you can locate and tighten the clamps correctly. You really better get the instructions and follow them exactly.
To do it right requires a long straight narrow blade screwdriver, a set of 1/4" drive sockets with long extensions. And a 1/4' drive coil-flex extension is a huge help.
If you try to just work it out yourself where to put clamps and what sequence to install things you will spend a lot of extra time. And some mistakes could sink your boat.
Get a detailed instruction set. It's faster and you'll be glad you did it right.
Doesn't matter which end you do first, as long as you do it right. As NH said, READ THE MANUAL.... Also, don't use a screwdriver to tighten the clamp, use a 5/16" socket on a long 1/4" drive extension... Doesn't slip off and you don't risk puncturing the new bellows...
