dlogvine
Thread starter- Joined
- May 4, 2015
- 839
I looked at my boat in the storage and found a little puddle of gear lube under the outdrive, right below the gimbal. Upon closer inspection I found a crack in the gear lube monitor hose. Now, is there a less invasive way to fix it, cut the cracked part out, the crack is located very close to the plastic nipple on the gimbal, or do I have to take the outdrive and gimbal off to reach this location? I'll post a pic later today. Also even though the rest of the gear lube monitor hose looks good, should I completely replace it, just in case there is some unnoticed deterioration? Thx
