Hello fellow boaters,
This has been an on-going problem.
The Boat
1998 Sea Ray 190BR signature
5.7 Liter with 1.47 GR Alpha One Gen 2
Prop Vengeance 21pitch
The Problem:
High power / High RPM (4000 or higher) evacuated lube reservoir from cap and messy engine compartment.
Attempts to correct:
1) pressure tested drive unit and found shift shaft seal leaking. Replaced with new and pressure tested. Still same condition
2) Replaced reservoir / cap with new. Same condition
3) Replaced upper and lower drive loaner from friend and appears to have improved but still evacuates reservoir with time. Different Gear Ratio unit though.
The engine is a very powerful 5.7 liter engine but should make any difference or so I am told.
I keep inspecting and replacing
the lube seems emerald green and stinky which I am told is normal. No milkiness.
Please help! Thanks all
The Boat
The Problem:
