Alpha one Gen 2 u-joints
Status
Not open for further replies.
Smokey988
Thanks! Pics and video and You will be blessed ;)
I assembled everything today and when I got to about 5 LB-IN for the rolling torque I loosened the nut 1/2 a turn and tried the deadblow on the threaded end while holding the bearing race but this did not work and lower the rolling torque at all. I was afraid to hit it any harder, so I tightened the nut until I hit a rolling torque of 5.5 LB-IN and called it good.
Scott06
I think you need to use more force to separate them like with a bearing splitter
Kubaat3lover
Bearings have to be separated a little bit before redoing the rolling torque. Either with a bearing splitter, or you can use a plastic deadblow hammer and give the shaft a solid tap to make a small gap before reassembling.
Inspect visually the bearings and races. Any marring or pattered shiny spots and they get replaced.
Can anyone please describe the deadlow hammer method??
Status
