OK folks, I've read the sticky's (great info), I've searched the threads and read hundreds of posts which have saved me countless hours getting the outdrive off correctly, and finally today the bell housing....
I'm pushing a 2004 Stingray 190LX with a 4.3L engine with Mercrusier Alpha One Gen II. I had been experiencing "growling" in all positions of the outdrive (up/down/left/right/load/idle). Nothing really made it worse or louder, and I could feel vibrations (slight) through the boat deck...
Problem started last winter while boat was in dry storage. When I parked it, I pulled the plug and apparently left it sitting on the swim deck. Some "nice guy" thought I had forgotten to put it in, and reinstalled the plug. When I pulled it out of storage this spring, I noticed an odd waterline (debris) in the engine compartment and partly into the seating area... then I noticed the plug has been screwed back in loosely.... ARGGHHH!!! Anyway, I'm guessing the water got up to above the shift entry point of the coupler....
When I got the bell housing off today, "brown" grease and water... so I know that's adds up to bad things... gimbal and possibly U-joints. Shaft has some "blueing" at the part where it begins to flare out before reaching the U-Joints. Figured that was from HOT gimbal smoking it.... (correct?)
Anyway... once everything was apart and prior to attempting to remove the gimbal bearing, I cleaned up all the grease (yuck) on the gimbal and it moves freely with my fingers... no resistance at all... however, I do hear some "scuffing sound" when i rotate it left/right... I figure it shouldn't make ANY sound... but it's not loose, no play, and moves very easily.
U-joints on the shaft articulate to full deflection in all directions with no sound, no resistance, no "catches". They are the GKN permaseal type, so I'm guessing if grease doesn't need to go in, water can't get in? Probably a bad assumption and I'm prepared to replace both, but with no evident damage to them, am I wasting money on this part?
My concern is growing that the amount of "growl" I was hearing at idle, drive in any position wasn't just the gimbal... I know, Water+Gimbal=Rust thus replace. I have alignment tool in transit now, so will most definitely get that right once new gimbal is in, but I'm wondering now if it's possible that the Couple could be growling???
I overcame my urge to crank up the boat without the outdrive installed today until I had time to research on here if that's good/bad/stupid thing to do... I would love to KNOW if having the outdrive out of the equation, would the coupler produce a "growl" in this situation, and is it safe to run the engine like this?
