brandonizr
- Joined
- Mar 5, 2007
- 19
So, changed the outdrive oil by pumping up from the lower screw hole till it poured out the top one, closed both up and added to the reservoir from the lid...
I read hear http://www.mercstuff.com/driveoil.htm that i should have closed the top screw and have kept pumping till the reservoir filled up...
Should i be alright how i've done it or do i need to drain and re-fill with that last minor step
Thanks
Thanks
