I have a 1993 3.0L Mercruiser. The throttle only button is stuck and won't work. I have tried taking it apart and spraying WD40 both through the button plunger and from the backside, where the shift/throttle cables come in. I have also tried taking a small screwdriver and trying to pry the plunger with no luck. Any suggestions are welcome. If I have to get a new controller, please suggest which model would work best. I'd like to swap them out with the least effort. I have attached photos to help you out.
Thanks!
