Is the gear ratio change in the upper or lower leg on the gen one out drives?
S Suprathepeg Petty Officer 1st Class Thread starter Joined May 25, 2015 Messages 259 Aug 3, 2015 #1 Is the gear ratio change in the upper or lower leg on the gen one out drives?
F flipbro Master Chief Petty Officer Joined Feb 8, 2013 Messages 830 Aug 3, 2015 #2 Gear ratio is determined in the upper. Shifting is done in the lower.
S stonyloam Vice Admiral Joined Mar 13, 2009 Messages 5,832 Aug 3, 2015 #3 The gear ratio and serial number should be stamped into the upper port side of the driveshaft housing.
